i installed the 2.1.1 fix and now nothing works...my crossfader and the gain controls dont work, and also it takes FOREVER to load, where as 2.1 didnt...I dont know whats wrong...Has anyone else experienced this? Can someone please help...Thanx
Posted Wed 28 Aug 02 @ 9:49 am
I have loaded 2.1.1 with no problems. Try reinstalling both the software and the patch, be sure to save your internal database file. If this does not help leave another message and I will try to help you sort this out.
.:DJ Homeboy:.
.:DJ Homeboy:.
Posted Wed 28 Aug 02 @ 3:10 pm
