Okay... here's my setup:
- Ibm Thinkpad laptop
- SB extigy
- Behringer VMX-200 mixer
What I would like to invest in now, is an external effect machine that can do more effects than the onboard effects in the Atomix-program.
Do anybody here have any suggestions?
(It has to be highly portable)
Thanks
- Jim
- SB extigy
Thanks
- Jim
Posted Sun 04 Aug 02 @ 11:17 pm
          there are a couple optios:
korg kaoss pad:
http://korg.com/gear/info.asp?A_PROD_NO=KP2
alesis air fx:
http://www.musiciansfriend.com/srs7/search/detail/base_pid/705591/sourceid=00205833055499286984
    korg kaoss pad:
alesis air fx:
Posted Mon 05 Aug 02 @ 7:38 am
          Thanks!  I'll check those out.
-Jim
    -Jim
Posted Mon 05 Aug 02 @ 11:21 am
          also check out redsounds line of products, they are detect bpm and sync the fx to them such as 1/2, 1/4 step delay, 2 bar filter sweeps etc.  They do exactly what i keep posting that the atomix fx need to give us the ability to do, maybe with the next version i hope.
or the pioneer efx500 is pretty sweet as well, basically the same bpm synced fx as the djm500 and 600 series mixers, ie time synced delay and flanger etc
Posted Wed 07 Aug 02 @ 6:09 pm
