Hi,
I got a Pro controller today. No documentation what so ever, and it doesnt plug and play. Anyone know how:
a) I load a song into the system? (guessing that once it is loaded I can play it)
Is there some swtich where I have to indicate that the controller is now in control?
The controller flashes on start up all its leds so i assume I have connected it the right way.
Proto
Proto
Posted Mon 24 Jun 02 @ 5:58 pm
Did you plug your controller on the COM1 or COM2 ?
To load a sond, just push the "Load button". Then press "Play"
You can find some usefull documentation here:
http://www.atomixmp3.com/controller.html
Posted Mon 24 Jun 02 @ 7:11 pm
Never mind. Seems it is a basic software problem. Not solved yet, but Yan-X has reacted very quick. So thumbs up for support so far.
Proto
Proto
Posted Mon 24 Jun 02 @ 7:18 pm
Ok no problem if you need any other assistance feel free to write back !
Posted Mon 24 Jun 02 @ 7:44 pm
