(nt = no text)
Posted Fri 24 May 02 @ 7:11 am
Many, including me would say SB Live! or Audigy, even I wish to try the SonicFury from videologic http://www.videologic.com/Products/VL-60444/ProductIntro.asp?Product=VL-60444 . Hope someone can give an opinion.
Posted Fri 24 May 02 @ 11:00 am
Terratec in pro version: not cheap at all! But the result is great!
Posted Fri 24 May 02 @ 12:51 pm
Terratec 6-Fire DMX. Best 24/96 6 channel consumer card available.
Audigy is crap compared to Terratec. Its not even true 24/96, and still upsamples all audio to 48KHz badly. It can't record in 24 bits, or for that matter at 96KHz, and it cant even play back 24bit, 96Khz files. The only thing it can do is *pass through* a 24/96 digital stream from you DVD drive to an external decoder.
Posted Sat 25 May 02 @ 4:46 pm
Thanks !!
Posted Mon 27 May 02 @ 2:48 am
how much?
Posted Mon 27 May 02 @ 8:59 am
Go straight here: http://music.multimedian.com/reviews/ewx.html
Posted Mon 27 May 02 @ 1:43 pm
I'm DJ and I want a seconde line out to listen to the music before put it in my mixe
Posted Mon 27 May 02 @ 5:41 pm
A sound card with 3d fonction. For ex., you may use a SB live/value/extigy (or the terratec 24/36, the best sound card, sûre!)
With trial, it's not possible. With trial + crack, it's not possible, too :))
Posted Mon 27 May 02 @ 11:08 pm
