Hello,
I purchased the latest version of Atomix from this website. I got an email w/ the link and downloaded. I entered the serial number give to me, but when I try running the program I just see the logo and thats it.
I run Windows XP and had the demo version before. That one worked perfectly. I know it doesnt have anything to do w/ resolution. I've tried re-installing but that doesnt help.
Can someone please help me. I paid $60 and want it to work
thanks.
thanks.
Posted Fri 24 May 02 @ 6:34 am
Please mails us to service@atomixmp3.com, we'll help you to fix this problem.
Posted Fri 24 May 02 @ 7:48 am
There was nothng I could do. When you said that you just saw the loop do you mean the graphic that says Atomix? I just went back to using th trial cause I didn't pay for the full anyways.
Posted Fri 24 May 02 @ 2:52 pm
same here i justsee the logo and its in the in the close program box(alt +ctrl+del) but its not n the start o nehing is like hidding whthout givin m a song and a dance like very one else can u tell me what to o?????????
Posted Tue 04 Jun 02 @ 6:00 am
