I've just bought atomixmp3 and it's really good, but I've got some problems with the skins ... when I press download my explorer shows lots of different letters etc.
Do I have 2 copy them in my skin file or something ?
I don't have a clue so plz help me
I've read in the details of another skin that there is a new version of atomix -- 2.1
Where can I find that update ?
Thx for helping me out
GnoedeL
GnoedeL
Posted Tue 22 Jan 02 @ 8:47 pm
The update is not ready for the moment, we have to wait ;). The new skin are just ready!
you have to unzip the files in ../atomixmp3/skins.
Sometimes, to download the zip file, you need to click on open instead of save -&rg this is due to IE
Hope this helps, Adrien.
Posted Tue 22 Jan 02 @ 10:26 pm
Sometimes, to download the zip file, you need to click on open instead of save -> this is due to IE
Posted Tue 22 Jan 02 @ 10:29 pm
Thx for the help, it worked !!!!!
Can I ask you for another favour?
Plz tell me how the loop works cos I'm pressing "L" like hell and it doesnt really work ... it's probably my mistake or something
Thx
Thx
Posted Tue 22 Jan 02 @ 11:07 pm
Make sure that the Deck you want to loop is selected, with the Yellow button on the Default skin and press L, with the diferent combinations for 2, 4 and 8 Bits loop. Check out the shortcuts on the option section (?).
regards
regards
Posted Tue 22 Jan 02 @ 11:37 pm
