Topic: Hercules Console Jogwheels
Is there a way to make the jogwheels more sensitive? I found that it makes for nice scratching (when you pause the deck your using for scratching), but in order to get nice scratches I have to spin the jogwheel at least 180 degrees (half way around), and its hard to do quickly while still keeping your fingers on the jogwheel (since you have to do 180 degree arcs and the jogwheel is small).
I know you can use the little joystick, but it isn't as precise (depending on where you start your arc movement, it will spin the record forward/backwards a lot or a little... you never know). Also, its very sensitive (if you only wish to scratch one beat, such as the beginning of a song, you're there trying to move the joystick like 2 millimeters back and forth). Doing this works great with a paused deck and the jogwheel though, but like I said, you have to spin the jogwheels 180 degrees (wheras 100-120 would be much easier and therefore more precise).
This isn't possible through the mapper is it?
Posted Sat 06 Dec 03 @ 6:05 pm
