Topic: Problem with Atomix
Hi, ive been using atomix since 1.0 and had no real major problems with it yet.
Now all of a sudden as soon as i try to load it, it says 'the internal database is corrupt' and quits the program.
Any idea how to fix it please?
much appriciated
Jon
Posted Sun 11 Nov 01 @ 8:27 pm
Only one possibility : Erase the two files called "(...) Database" in your home directory
Yan-X is right. Sometimes it can happen :(
To avoid it next time think to backup these file as soon as you can !
I've also had this problem a few times over my months of atomix use... Deleting the internal database files works, but you loose the BPM and level information until you play your songs again.
I wonder... is there a way to have atomixmp3 scan your home directory and extract all the tempo/level information? It'd be nice if I could just have it start scanning all the MP3's before I go to bed for the night and wake up with all the info there.
this is one of the new version's features :)
Stephane C.
