Hi everybody,
I'm toying about the idea of buying a mixer to connect with Atomix. It would be great if I can get some cool advice from those who already experience with mixer+atomix.
Here is my config:
PIII 800MHZ, 166 RAM, 2 soundcard
Question 1: Can I control the volume through the mixer instead of using the mouse?
Question 2: Is there any other beneficial use of a mixer over the crossfader built in Atomix?
Question 3: Which mixer is good for beginner?
Thanks a bunch... you guys are a great clown
Here is my config:
Posted Tue 24 Jul 01 @ 10:08 pm
Answer 1: Yes, you just let the volume at the maximum on Atomix, and you adjust the volume on your mixer
Answer 2: With an external mixer you can mix with another sources, you can add effetcs...
Answer 3: I have no idea for this, I have a professionnal mixer... Sorry... :))
- Dams -
- Dams -
Posted Wed 25 Jul 01 @ 9:54 am
Hi,
I think any mixer with three band equalizers on each channel will satisfy you. Ask for one that cuts the different frequencies (low, mid, high) well. If you want to use it only with Atomix, you don't need any BPM counter or flashing led. A two channel mixer should be enough too. Maybe you'll need more than two channels if you want to plug a safety CD deck in case your PC crashes. But on most of the mixers, there are two stereo entries on each channel : one for CD decks, and one for turntables. The impedance is not the same, but sometimes you can switch the turntable entry into a CD deck entry. Thus, you can use more than 2 stereo entries on a two channel mixer and plug a CD deck (you'll just have to switch between phono/CD if the PC crashes).
Anyway, ask your reseller to give you some pieces of advice :)
The main benefit of using an external mixer is that you can use your two hands at the same time ! Besides, you cannot mess up like with the mouse sometimes.
Hope that helps.
Hope that helps.
Posted Wed 25 Jul 01 @ 10:49 am
thank you guys... I'll buy a Stanton SK2F... any advice b4 the final purchase?
Posted Thu 26 Jul 01 @ 4:16 am
