Topic: System requirements
I was wondering if you have any system requirements. My friends want to use something besides Winamp to DJ with. The only problem is that the PC they have is a Pentium 133 with 64 megs of memory. Is that enough?
Posted Wed 07 Feb 01 @ 4:39 am
Doubt it'll run - the demo only just runs cleanly on my P200 with 32 MB RAM. The sys. requirements are something like a P166 with a PCI soundcard and a P233 with an ISA soundcard. My PC has an AWE 64 ISA card, and the mix sometimes gets well out of sync 'cos the card can't cope, neither can the PC. Try the demo on their PC's anyway, you never know, it may work.
Hmmm tricky, try it!
I'm using a PII366 Notebook with 128MB of ram, it will stutter etc if I have other programes open. On my Desktop Celeron 500Mhz with 128MB ram.....no problems whatsoever.
Adam
