Topic: track cleaner no sound
good day everyone ... im been trying to use the track cleaner to edit some song but to no prevail ..... problem is when i open track cleaner to edit the is no sound when i press play but back on the decks its fine i go back to track cleaner no sound is there something im missing or is there a setting im overlooking ..
my computer spec are as follows
WINDOWS 11
hp intel I9-9880H
CPU 2.3Ghz
Ram 128 GB
Graphix 8 GB ( NVIDIA QUADRO RTX 4000 ) / Intel UHD graphix 630 ( 128 MB )
HD 24Tera
any help i appreciate it thank you
Posted 3 hours ago
If you have headphones configured in your audio setup the track cleaner will play in the headphones
i tryed that also everything it does nothing but on decks is working fine
Adion thank you i had to reconfigure had to add a second line for headphone to chan 1 & 2 it worked thanx
