Hi, as part of my big multi year jump to the latest build I can no longer find the really useful colour picker that you could also enter your own #000000 number in. I used a specific colour hex code to mark tracks I want to remove later. So where has this useful picker gone in 2026? I looked at the color options on settings but no luck. Any help please?
Posted 7 hours ago
setting colorpicker
you probably want system.
but honestly, I just use a keyboard key to send tracks to the last chance listening filter
loaded_song color "#00FF00"
browsed_song color "#00FF00"
Posted 7 hours ago
Many thanks. I guess that's a work around, however system brings up windows version (pro skin). The previous inline VDJ box was so flexible/compact, I wonder if the Devs would consider bringing it back as an option (please)?
Posted 6 hours ago
Right-click the color drop-down to enter the value manually
Posted 6 hours ago
