HI,
my controller offers a button that in activity is shown as T_MODE=on/off.
Question: how can I evaluate that state in script?
I want to remapp my "loop" button as follows:
$t_mode = 'on' ? loop_select 1 & loop : loop
T_MODE = 'on' ? ...
Tried both without success.
Any idea?
I have a Reloop Mixtour controller, if that matters.
T_MODE = 'on' ? ...
Any idea?
Posted Thu 28 May 26 @ 9:53 pm
t mode button calls this
set cuemode 0
therefore, your loop button should be mapped as so
set cuemode 0
var cuemode 0 ? loop_select 1 & loop : loop
Posted Fri 29 May 26 @ 1:33 am
I ment I want to detect the "while t_mode button is pressed down" state.
cuemode 0 is a state that is also active when t_mode button was released (it only switches the cuemode-banks).
Posted Fri 29 May 26 @ 7:28 am
t mode button
set cuemode 0 & set $myShift 1 while_pressed
var $myShift 1 ? loop 1 : loop
Posted Fri 29 May 26 @ 7:30 am
Thanks a lot :)
Posted Fri 29 May 26 @ 2:08 pm
Today I discovered my mapping sadly does not work.
This is what I have:
PLAY Button: var $t_mode 1 ? play : pause
T_MODE Button: set 'cuemode' 0 & set '$t_mode' 1 while_pressed
I would expect the PLAY button to only play if T_MODE button is pressed. Otherwise it should pause, and thus NOT play anything.
BUT: whenever I press PLAY, it starts playing. No matter if T_MODE is pressed on not.
What could be wrong?
Posted Fri 07 Aug 26 @ 11:56 pm
Hmm, the solution is to use the variable without $:
set 't_mode' ...
var 't_mode' ? ... : ...
set 't_mode' ...
Posted Sat 08 Aug 26 @ 12:02 am
