Is there a program that allows you to convert existing PNG, JPG, GIF, BMP files into the VDJ Shader format?
I would like to integrate my own custom-created clips into VDJ Shaders.
In the past, there were Telly Media and Telly Visuals, which allowed you to use all these files very effectively in VDJ unfortunately, however, they are no longer available.
Posted Tue 19 May 26 @ 9:22 am
visuals plugin will play .mp4 once it's been named VIDEO and wrapped in a .vdjshader container [the AI videos are .mp4].
I was thinking about making an app to ffmpeg whatever source material to .mp4 and then do the .vdjshader wrapping.
I did ask the devs about the visuals plugin accepting other file formats, I got a 'it could' reply, which leaves me optimistic.
Posted Tue 19 May 26 @ 10:21 am
Your answer is very interesting; please stay on it
Posted Tue 19 May 26 @ 10:28 am
Agreed, it would be good if the visuals could somehow be combined or linked with the slideshow, enabling transitions to be used, timing adjusted, shuffling etc. rather than being restricted to one or the other.
Having the sampler be able to accept the wrapped "visuals" files too, so users could trigger specific shaders or AI clips directly from the pads like other formats.
Posted Tue 19 May 26 @ 10:41 am
Hi Locodog,
you wrote above "and wrapped in a vdjshader container"
How do you add a file to the shader container, so that it is integrated into the shaders and can then be used?
There is no input capability for shaders!
Posted Tue 19 May 26 @ 1:33 pm
open a .vdjshader with 7z or whatever and you'll see.
Posted Tue 19 May 26 @ 2:20 pm
Hi Locodog,
I opened a vdjshader file, but all I see are hieroglyphs. I don't know where I need to make changes!
I placed the file into the appropriate "Visualizations" directory—it shows up in VDJ, but I can't activate it.
I also edited the "shaderslist.xml" file, but nothing works.
What am I doing wrong?
Posted Tue 19 May 26 @ 4:02 pm
open with 7zip, visuals that start with 'v_' are video based, inside you'll see the .xml that holds the metadata, the video.mp4 & the thumbnail.jpg
actual shader visuals of course don't have a .mp4, the have a .cso [Compiled Shader Object File]
Posted Tue 19 May 26 @ 4:38 pm
Hi Locodog, have you made any further progress on this?
Posted 5 days ago @ 9:24 am
I haven't thought about it at all.
Clients and my own projects on the go so busy with my own stuff.
Posted 5 days ago @ 4:23 pm
