Hi there. I'll try to explain the problem briefly: Windows, drivers, and Rane Performer firmware are all up to date. I've tested it with Midi 2.0 both enabled and disabled, and I have also performed a clean reinstall of VirtualDJ, deleting everything. When it detects the Rane, it configures it as WASAPI without separate channels. In this mode, I can open and close VirtualDJ without any issues. However, if I configure it correctly using ASIO drivers as per the hardware manual, it works perfectly with all its features, but when I close VirtualDJ, it seems to close but remains running in the background. When I try to run it again, it says it is already running. Since it doesn't actually close, it doesn't save the latest settings either. The only way is restarting Windows, and do the config again.
Thank you for your time.
Posted 3 hours ago
