I am trying to create a script that will do a fluid analysis so that when loading any song in the deck, it will change the song from rigid to fluid in the BPM editor. I basically want a shortcut that will do the same thing as going into the BPM editor, and then selecting fluid.
But if I do this, will this mess anything up when loading a song that does not need a fluid analysis, such as an EDM track?
Or maybe there is a script that will only change the track from rigid to fluid if the track needs it? That will be preferable.
Thanks.
Thanks.
Posted 2 hours ago
