Hi,
Apologies if this is a repeated question, I've searched and can't find my specific requirement.
I need an controller button led to turn on when the button is pressed and for it to stay on however many times I press it. Straight forward enough. I then need to be able to turn it off when pressed whilst holding shift.
Thanks
Thanks
Posted 8 hours ago
So to think about the button, not the LED pressing it turns something on until shift+button turns it off.
LEDs just query something, so what script do you have on the button as a press action and then we can work out the rest
Posted 7 hours ago
ok this is what I have
Currently that organises the tracks when in browser view by artist and toggles the button when not in browser view
controllervar '$d2browser' ? browser_window 'songs' ? browser_sort 'artist' : sideview_sort 'artist' & nothing : toggle "$Button1"
Posted 7 hours ago
and the shift+button script please.
I'm guessing here map your LED to
Posted 7 hours ago
Probably a bit more context of what this is for might help.
The button currently sorts the browser screen, when not on browser screen I have it firing through my midiloop device to ableton to start a clip over there, which works well. I need led confirmation to say it's been pressed and then switch off when shift pressed to show that clip has stopped.
This is the button code
$Button1 being the var sent through Midiloop to start the clip in ableton and that restarts the clip on every press.
This is the shift button code
$Button1S being the var sent through Midiloop to stop the clip in ableton
This is the led code if needed
I thought tweaking the end of the led code would get the desired result but maybe i'm coming at it from the wrong angle!
controllervar '$d2browser' ? browser_window 'songs' ? browser_sort 'artist' : sideview_sort 'artist' & nothing : toggle '$Button1'
toggle "$Button1S"
controllervar '$d2browser' ? browser_window 'songs' ? browser_sort '-artist' ? on : browser_sort '+artist' ? on : off : sideview_sort '-artist' ? on : sideview_sort '+artist' ? on : off : off
Posted 7 hours ago
I see a bit more complicated than first thought but simple to deal with
BUTTON
controllervar '$d2browser' ? browser_window 'songs' ? browser_sort 'artist' : sideview_sort 'artist' & nothing : toggle '$Button1' & controllervar '$myLED' 1
SHIFT+BUTTON
toggle "$Button1S" & controllervar '$myLED' 0
LED
BUTTON
SHIFT+BUTTON
LED
Posted 7 hours ago
That's excellent, thanks mate, works great.
Now I see the code I see it is simple, I was trying to do it all on the led, which obviously wasn't the way.
Posted 6 hours ago
@Locodog is a genius!
Posted 6 hours ago
