Topic: Problem with beatjump and grid
Hi everyone, I decided to try switching to VirtualDJ from Traktor.
I noticed that when I change the grid, beatjump doesn't snap to it. Here is a screenshot from VirtualDJ and Traktor of the same track. The difference is more than 1 beat. Is there any way to solve this problem?
Posted 5 hours ago
Not sure what you mean by change the grid, but beatjump should follow the globalQuantize setting - setting that to 1bt in the settings should be enough.
I did it but its does not work
I can see there's a beat missing. You've only got a three count on the 4th bar. What's the track? Is it supposed to be like that (is that what you meant by "change the grid")?
Oh, thanks for answer, I understood.
