I have a question. Can the Automix function play on two decks? Because I noticed that it always works on one deck. Thank you in advance for the information.
Posted 2 hours ago
Yes there's a setting for dual deck automix however it's a deprecated feature and it's better using the single deck instance.
Posted an hour ago
Could you describe how to do this? Thanks in advance.
Posted an hour ago
Go to settings and search for dual.
Posted an hour ago
