When I customize an effect like echo out, the changes aren’t saved session to session. I was expecting the settings to be remembered the next time I open VDJ. Any idea how to keep the settings? Thank you
Posted Thu 29 Jan 26 @ 11:20 am
FX settings DO get saved. However, if you use a controller these settings may get overridden when you start VirtualDJ because controller controls (knobs and sliders) take priority.
So, as a first troubleshooting step, test if FX settings stay when you use the program without a controller.
If they do, then we can talk about what other steps you can take to minimize the issue when you use a controller (as it's more or less controller specific)
Posted Thu 29 Jan 26 @ 11:42 am
Thank you for the reply and you are correct! I opened VDJ without being connected to the controller and the setting help. Closed, connected to the controller and reset the settings. I have a pioneer did-sb2 and denon mc4000. Thoughts on how to fix?
Posted Fri 30 Jan 26 @ 11:53 am
Check their manual and set them to 3FX mode if applicable.
This way, only the first parameter (dry/wet) will get overridden by the controller..
Posted Fri 30 Jan 26 @ 1:07 pm
Unfortunately, they don’t have that mood in the controller. Apparently it has to be done the other software for me to control all the parameters, including feedback, reverb, color, etc..
Posted Fri 30 Jan 26 @ 5:02 pm
Any new tips on this? Thanks
Posted Tue 03 Feb 26 @ 3:17 pm
