Installed 2026 over the last, latest version of VDJ. The sound is screwed up. All songs are raised by 4 semitones and it sounds like the bitrate of all my songs are like 64kbps. Tried rebooting but no luck. Uninstalled and reinstalled 2025 8809 and it's normal again. Doesn't appear to be a download link to 2026 for a fresh install. Anyone else have this issue? Is there a link to 2026 so I can do a fresh install?
Posted 7 hours ago
OK I figured it out. For some reason, on the audio tab, Deck 1 Color Effects dropdown had the Pitch button engaged. Not sure why that changed. The only change I made prior to updating to 2026 was add a color rule to each deck indicating when a track is loaded on deck 1, the color will be blue, deck 2 color will be red.
Posted an hour ago
