Hello,
At home I use an inpulse T7 premium to mix and learn scratching.
I can't find the "instant double" function.
On the FLX10 you have to press the rotary selection knob twice.
But on the T7 it doesn't work.
Is there another thing to do?
Posted 4 hours ago
In the FLX10 mapping, the command on the encoder push is
doubleclick ? clone_from_deckso you could possibly add that to the same encoder on the T7
Posted 4 hours ago
