Topic: PIONEER FLX 10 PROBLEMS
Dear everyone,
I’m having a problem with my Pioneer FLX10 controller. Specifically, here’s what’s happening:
Within the pad section, when I select Pad FX — I tried both the original settings and creating new ones — I managed to set Pad 7 to Echo Out and Pad 8 to Reverb, and everything worked great. Then I set Pad 6 to Break Start, and that also worked perfectly, both on the left and right decks, using the Custom mode.
However, when I switched to the 4-deck mode, everything still worked fine on Decks 1 and 2. But on Decks 3 and 4, Reverb and Echo Out work perfectly, while Break Start doesn’t do anything.
I tried adjusting some settings, but now everything is completely messed up — when I press Break Start on Deck 3 or 4, it triggers Echo Out instead.
Could you please help me fix all these problems and set up my device so that it works simply and properly?
Posted 24 hours ago
HOW you "managed to set X pad do Y thing" matters a lot.
So let us know what did first. Try to provide as many details as possible.
I will send video so you can see, i asked and chat gpt for help, but still had lot of issues ,so i will record it all
Chat GPT isn't going to help with a specific problem on a specific controller with specific software.
I saw this post but I didn’t figure out what to do, can someone please make some video instructions , whats i need to do ? 🙏
