Topic: stems engine error
I just got a new m1 MacBook Pro (maxed out) and now it says " stems engine error" and doesn't work. HELP !!!!!!!
Posted Tue 30 Sep 25 @ 2:10 am
Did you set up your mac as new computer, without restoring from any backup or transfer data from old computer during setup?
Did you copy any data to the virtualdj install folder from old computer except music files or database.xml file ?
Few months ago I had similar problem and it was explained to me that because of macos security/signatures you need clean install for virtual dj in order for stems engine to "misuse" the video card for stem engine. Just deleting virtualdj was a no go. I had to do clean install of mac os again and properly install virtualdj from the website
However it was few month ago and maybe situation is different today.
