Hi everyone, I recently purchased a ddjflx10 and are uing it with virtual dj, i noticed my controller goes into a demo mode after 10 minutes when not touched, this is easily turned of on the pioneer, however as soon as i plug it into virtual dj, this setting gets reversed, i cant figure out how to stop this, have done a factory reset, firmware update etc... but no luck, any help would be appreciated, thanks
Posted Sun 31 Aug 25 @ 7:33 am
Did you try adjusting the setting PIFLX10-demoMode (only appears when the controller ia connected and VirtualDJ detects the connection)? If you didn't adjust that setting then please try it - I think that is the setting that VirtualDJ applies for the demo mode timeout.
Also checkout all of the settings specific to that controller in the manual written for the controller:
https://www.virtualdj.com/manuals/hardware/pioneer/ddjflx10/advanced.html#settings
The devs really do take time to write fairly detailed manuals for the supported controllers and that should always be the first stop for knowledge on how to use the controller with VirtualDJ.
Posted Sun 31 Aug 25 @ 1:59 pm
