Hi. Yesterday I updated Virtual DJ (I’m not sure if my problem is related to that), but since the update, in my library and everywhere else—even if the song is stored locally on my hard drive—when I check the file info, it says the song is online.
If I completely disconnect my laptop from the internet, the song still loads. So that means it’s being accessed locally from the hard drive. But the file path shows as if it’s online.
I’ve checked and I don’t have any subscriptions to anything, no providers at all—no Cloud, no Tidal, nothing. But without the internet, the local songs don’t even show up. When I search for them, they’re not found.
I have no idea what to do. I have filters for all my folders, but those filters seem to point to an online drive that I don’t recognize. I really don’t know.
Basically, I need help because my entire library is all messed up. I checked, and I have no online search services enabled. For example, there’s nothing set up to search on Beatport, iCloud, or anything else. I have no links that should connect to anything online. I really don’t know what to do.
Posted Wed 25 Jun 25 @ 6:54 pm
Not straight forward subject ..
I'll look forward to do a database backup before any modification, do you have a recent older one ?
I'll check whether Windows (onedrive) or Apple (Icloud) didn't do an update of the repository where tracks are an join it as an online repo.
I'll open a ticket with support to see if it is a known case an whether this is an easy database mod with info of the source version of VDJ and updated version.
I'll try to identify exactly what is not working whithin the search and i f i haven't got any filter with online file search so that i'll be able to work with the issue while waiting for support.
I'll try the vdj extension "my library", see if it helps.
I am not a Vdj tech so try them @Support_staff, before community, and see
Posted Thu 26 Jun 25 @ 9:22 pm
I'm not sure but think it say streaming and this happened to me awhile back.
Posted Fri 27 Jun 25 @ 6:57 pm
