Does anyone know of a feature I can use to perform the same function as Smart_Fader but with out affecting the EQ. Currently when I'm mixing two songs using Smart_Fader and the crossfader is at 50% the bass drops out. I tried mapping a key using the action (Smart_Fader & eq_reset) but that didn't work. I also tried mapping a key to turn on and off autobpmtranission but it goes inactive after 2 to 3 seconds. What I'm trying to do is blend Vocal and Instrumental using deck one and two with features of Smart_Fader active but without affecting the EQ. Any ideas would help thanks.
Posted Wed 28 May 25 @ 10:50 pm
Posted Fri 30 May 25 @ 12:51 pm
Closed.
