The gain seems to have a mind of it’s own
I move it manually and then it goes back
Posted Fri 16 May 25 @ 3:15 am
Check your settings.
Probably you want to change the "resetGainOnLoad" option to no.
HOWEVER, keep in mind that if you find your self needing to have the gains constantly on a position different than "12 o clock" then your real problem is not gain itself.
You either need a more powerful PA (if you constantly keep gains past 12 o clock) or you need to lower VirtualDJ's headroom (zeroDb setting) if you constantly keep gains prior to 12 o clock.
When using ANY DJ software with it's autoGain enabled (recommended for all, VirtualDJ, Serato, Rekordbox DJ, Traktor, e.t.c.) gain sliders should generally sit at "12 o clock" position and you should only have to do minor gain adjustments here and there on an odd track or two..
PS: If you have changed other gain settings like autoGain, and "gainsliderIncludesAutoGain" please set them back to their default settings.
Posted Fri 16 May 25 @ 7:55 am
