Hi everyone ! Is there a way (script) to add a song playing now on the deck to the list / folder without selecting it. add_to doesn’t work, cos you need to select a specific file. Thank you.
Posted Sat 25 Jan 25 @ 9:44 am
if it's on deck just drag the file from the cover art to the list.
Posted Sat 25 Jan 25 @ 10:24 am
Thanks. I would like to do this with a key without highlighting the file. Is it possible?
Posted Sat 25 Jan 25 @ 10:35 am
BTW: get_loaded_song 'fullpath' & param_cast & playlist_add
^This should do what the OP asked for..
Posted Tue 28 Jan 25 @ 7:34 am
It Works ! Thanks a lot !!!
Posted Tue 28 Jan 25 @ 8:18 am
