Topic: Shader on Audio only issue
I use VDJ with videos, sometimes I have to use Audio files. On the configuration panel I assigned "Audio Only / Shader". But I can´t change the shader, and the "Auto Change" option is check. Also when I click on Shader in the principal window and I try to change the shader, the bar shows the shader´s name, but in the video window I just have a black screen
Posted 4 days ago @ 3:18 pm
Sometimes there is a bad shader in a group of them. Maybe figure out which one it is and delete it. I find some that get stuck that I use and I just delete them.
Posted 6 hours ago
