Hai Expert! I need guide on my Virtual Dj Pro License
I am using Virtual Dj with Pro License at home PC for Training purpose & use the same Virtual Dj Pro License on my Laptop for Club play. Do I get the same Hot Cue Point with My Virtual Dj Pro License or its need to be activated in Virtual Dj Pro License
Posted Tue 21 Jan 25 @ 4:57 am
hotcues are stored in the database, licence doesn't even come into it.
Posted Tue 21 Jan 25 @ 5:13 am
Hotcues, among any other info regarding your files are stored locally on each computer.
As Locodog said, it doesn't matter what license you have.
If you want the hotcues and info from your home computer to appear on your laptop, you have two options:
1) Synchronise manually
2) Explore the CloudDrive functionality in VirtualDJ if you have a cloud service provider.
Posted Tue 21 Jan 25 @ 8:08 am
ok thanks. how do i connect with cloud services.
if manually to do Hot que it's a long way to do it. its will easy if i get connected with pc to my laptop. please do guide me
Posted Tue 21 Jan 25 @ 2:01 pm
