Hey, do you know any way to transfer the Virtual Dj playlist to Denon Engine Dj?
Posted Tue 14 Jan 25 @ 9:24 am
You can do it through iTunes. I converted all my lists and they work on my Prime Go+
My files are on the SD card in the same file structure I use in VDJ so that probably helped.
Can't remember exactly what I did though. You need to use the VDJ Export function to create the playlist, import it to itunes then it is visible in Engine I think.
Posted Tue 14 Jan 25 @ 9:36 am
