With the new v2025 b8472 Build after some hours I get sometimes a "Stem-Engine Fehler" (=Stem-Engine Error) precalculating stems. Log Report.txt logs "Stem Engine Error 662/1". What might be the problem?
I'm afraid getting this during a show - that would definitely be unfriendly ...
System Report:
--- VirtualDJ System Report --- 850.8472.pc64 --- 2024-12-25 17:29 ---
-- System info --
CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
Stems Speed: 4.6x - GPU (NVIDIA GeForce GTX 1650) (Mem)
GPU: NVIDIA GeForce GTX 1650
Memory: 32495 MB
Power Mode: Balanced
-- MIDI Devices --
Midi out device: drivernameout="Microsoft GS Wavetable Synth"
-- HID Devices --
HID Device (unknown): vid="0x8087" pid="0x0A1E" path="\\?\hid#intc816&col01#3&36a7043c&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}"
HID Device (unknown): vid="0x8087" pid="0x0A1E" path="\\?\hid#intc816&col02#3&36a7043c&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}"
HID Device (unknown): vid="0x056A" pid="0x490A" path="\\?\hid#wcom490a&col02#5&10d33648&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}"
HID Device (unknown): vid="0x056A" pid="0x490A" path="\\?\hid#wcom490a&col03#5&10d33648&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}"
HID Device (unknown): vid="0x056A" pid="0x490A" path="\\?\hid#wcom490a&col05#5&10d33648&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}"
HID Device (unknown): vid="0x06CB" pid="0x7A13" path="\\?\hid#syna2393&col03#5&1f439a5f&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}"
HID Device (unknown): vid="0x045E" pid="0x0000" path="\\?\hid#converteddevice&col02#5&379854aa&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}"
HID Device (unknown): vid="0x06CB" pid="0x7A13" path="\\?\hid#syna2393&col04#5&1f439a5f&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}"
HID Device (unknown): vid="0x045E" pid="0x0000" path="\\?\hid#converteddevice&col03#5&379854aa&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}"
-- Audio Devices --
Audio device: asio="ASIO 2.0 - ESI UDJ6" hardwareID:"6E15041D-ECE6-42DE-B5EA99C7BAE1AA4D"
Audio device: asio="ASIO4ALL v2" hardwareID:"232685C6-6548-49D8-846D4141A3EF7560"
Audio device: asio="Realtek ASIO" hardwareID:"A80362FF-CE76-4DD9-874A704C57BF0D6A"
Audio device: input name="DroidCam Virtual Audio" hardwareID:"{0.0.1.00000000}.{fc05f23b-356b-4444-bd7a-4c4a3e8869e9}"
Audio device: input name="Realtek(R) Audio" vid="0x10EC" pid="0x0298" hardwareID:"{0.0.1.00000000}.{a8d6b70b-e12c-460a-a62a-e075c04ad8a3}"
Audio device: name="Realtek(R) Audio" vid="0x10EC" pid="0x0298" hardwareID:"{0.0.0.00000000}.{39ad098f-d21b-47fe-b122-a917024be9f6}"
-- Audio Devices Used --
wasapi://{0.0.0.00000000}.{39ad098f-d21b-47fe-b122-a917024be9f6} (Realtek(R) Audio) 48000 Hz, 32-bit (float), 2 chan, 1056 samples (shared)
-- Audio Error Log --
[15:40] wasapi://{0.0.0.00000000}.{39ad098f-d21b-47fe-b122-a917024be9f6} (Realtek(R) Audio) : expected: 48482 / received: 41760 (cpu: 4.15%) (1x)
-- Audio High Cpu Log --
[15:40] wasapi://{0.0.0.00000000}.{39ad098f-d21b-47fe-b122-a917024be9f6} (Realtek(R) Audio) : Peak cpu: 452.81% (1x)
-- Controller Reconnect Log --
-- Performance Log --
Performance stats (session duration: 02:23:20)
avg peak audio cpu: 2% - low skin fps avg: 28 fps - periods with skin drops (<24fps): 5% - periods with skin drops (<15fps): 1%
-- Database --
Loading database C: (18.90 KB)
Loading database D: (60.55 MB)
Database loading time: 9566.59 ms - Number of entries: 50926
System Report:
-- System info --
Memory: 32495 MB
-- MIDI Devices --
-- HID Devices --
-- Audio Devices --
-- Database --
Posted Wed 25 Dec 24 @ 11:52 pm
