Topic: Sound gap settings
Hi everyone.Do we have any solution about the gap in the sound that it makes when we push apply in the sound settings?When i have an older macbook (2014 with macos high sierra) i didn't have this problem with any change in the sound settings.
Posted 5 hours ago
If you're referring to windows then that buttons resets the drivers so of course there is going to be a gap.
Posted 5 hours ago
For example if i play with djm900 at 1-2 line and i want to change to 2-3 when i do the change at sound settings and push apply it does a big gap at the sound.But with my older pc i didn't have this.
Posted 4 hours ago
Well you got lucky with your old machine, refreshing audio config it is completely expected that there is a small break in the sound.
It's just not something you should be doing in performance.
Posted 3 hours ago
