Everytime I try to edit one of my samplers I have to close vd and open it. That bug definitely need to be fixed. Please hurry!
Posted Mon 02 Dec 24 @ 9:26 pm
I don't have that problem
Posted Mon 02 Dec 24 @ 10:04 pm
I definitely didn't have that problem before the update today.
Posted Tue 03 Dec 24 @ 3:15 am
what do you mean by "have to close vdj and open again" ?
Posted Tue 03 Dec 24 @ 7:23 am
When I go into sampler editor and edit the sample how ever I want it then save it and come back out the sampler editor, noting has changed. So I have to exit vdj as it close the software and open it again then do the whole sampling process again. And if I want to edit another sample (which I do) I have to do that all over again.
Posted Tue 03 Dec 24 @ 12:44 pm
instruments sampler which was already there had been vanished
Posted Tue 03 Dec 24 @ 1:18 pm
will be fixed in new build, coming soon
Posted Tue 03 Dec 24 @ 1:30 pm
yes the old banks have been replaced with newer fresher ones.
the LOOPMASTER bank is the replacement for INSTRUMENTS.
If you want to get the old banks anyway, go in settings->extensions->samples->instruments and search "v8"
Posted Tue 03 Dec 24 @ 1:32 pm
