Topic: Sampler problem in Project Control skin
Hi Guys, I run Windows 11 and have the latest vdj 2025 pre release build. Two problems I've found with the sampler. First one, on the project control skin I have my sampler in squares I can click on with my mouse next to the jog wheel, see pic. My left samples , buttons 1 to 8 work fine when pressed but the right panel of buttons 9 to 16 colourize when pressed but no sound. I use them as radio drops.
Also, and this is annoying, when I try to adjust the gain of the sample and save it, it doesn't save the adjustment. I get it, I'm on an early release build but I have had zero problems the the sampler before. All my sampler settings are exactly how they were before the new build was installed.
If push comes to shove, how do I role back to the previous stable build? Many thanks for any help.
Posted Thu 28 Nov 24 @ 4:17 am
set "audio output pads" to "sampler" in the sampler menu
Posted Thu 28 Nov 24 @ 8:15 am
Many thanks for your reply Stephane. However, that was already my default setting. It's got to be something with the new pre release builds. I'll have to go back to ta stable version I think. Or it's to do with the Project control skin.
Posted Thu 28 Nov 24 @ 1:08 pm
Just gone back to stable build and everything works perfectly, maybe I need to wait a few weeks before I get the next build.
Posted Thu 28 Nov 24 @ 2:13 pm
we'll release a new EarlyAccess shortly that changes this behavior, that should work better for you
Posted Fri 29 Nov 24 @ 7:24 am
