Hello everyone,
I'm looking for a script that allows me to scroll through the song using Shift and Jogwheels in the selected deck.
Procedure: I load a song in deck A, press Shift and turn the jogwheel and scroll in the loaded song. Like Pioneer Controllers.
Greetings and thx
Greetings and thx
Posted yesterday @ 7:06 pm
It depends on your controller, but for the most part try to remap your jog as shift ? touchwheel 'search' : touchwheel
Also you will want to remap the touch sensor of the jog to shift ? nothing : touchwheel_touch
Posted yesterday @ 9:20 pm
OK, thank you for the fast answer. For my Controller doesn't work, because it's a Rane One and have spezial Jogwheels. After a lot of time, I scripted:
Key: SHIFT_JOG
Action:
deck play ? ns7_platter : song_pos & songpos_remain
This script, works for me, if I press Shift + touch the jogwheel it scroll in the loaded deck with the new song .... (Condition deck doesn't play, if the deck with the new loaded song is playing, function is not active. Otherwise it makes no sense to me )
Key: SHIFT_JOG
Action:
Posted 17 hours ago
Posted 17 hours ago
