Went to look in to the Algoriddim fluid beatgrid to find out more about it and the Google automatic search population speaks for itself :)
I just updated my video for Billie Jean and re-analyzed in VDJ. As you can see the CBG is way off at the start of the song (where I'd normally loop the intro for a mix) but in the middle the CBG is better.
We really need this feature please!
Posted Wed 30 Jul 25 @ 10:39 am
Billie Jean first two bars are off. That's no secret to anyone.
However if you try to reanalyze_multi I believe it detects and fixes this.
At least I know that on my "version" of Billie Jean it's fixed..
PS: If you loop and sync on the first 2 bars, you better finish your mix before releasing the loop. Because otherwise the track will come out of sync right after those bars.
The only "viable" solution would be to re-grid / re-drum the track..
PS: 12 inch version does not have this issue :P
Posted Wed 30 Jul 25 @ 12:37 pm
