I have a question. After buying VIRTUALDJ PRO INFINITY, please write how the program will be updated in the future.
Krzysztof
Krzysztof
Posted Wed 24 Jul 24 @ 12:57 pm
The program auto updates regardless of the license.
Posted Wed 24 Jul 24 @ 1:00 pm
This I know. I'm more concerned about future versions, will I still have updates always to the latest version. After purchase VIRTUALDJ PRO INFINITY.
Posted Wed 24 Jul 24 @ 4:37 pm
The clue is in the name.
Posted Wed 24 Jul 24 @ 4:38 pm
YES, if your machine is connected to the internet then vdj will update with every new release.
If your machine doesn't go online, you can download the current version and then move the installer to your performance machine.
Everybody gets the same version of VDJ, home user, home plus user, full pro, all the same the difference is your login unlocks the extra features.
Posted Wed 24 Jul 24 @ 5:25 pm
And is it necessary to have a connection to the interet to have all available functions in the program. After purchasing the program. If this is the case, it is a very poor solution.
Posted Wed 24 Jul 24 @ 6:03 pm
It is not not necessary to have a connection to the internet.
HOWEVER "all available functions" include functions that rely on internet, such as streaming files directly from on-line pools.
Those functions will NOT be available if there's no internet connection.
Posted Wed 24 Jul 24 @ 6:05 pm
Thank you very much for all the posts
Posted Fri 26 Jul 24 @ 9:28 am
