Topic: Stem Script Help
I feel like I have asked this before, but I can't find it. I'm sure this is a simple one, but I am not good at stringing this scripts together. I am trying to use a POI to achieve the following:
1) Auto loop 4 beats when it reaches a certain point in the track (did this with no problem using the auto-trigger loop)
2) After the track loops twice, remove the instrumental stems at the beginning of the third loop (leaving only the acapella)
3) Once it reaches the point where instrumental stem is removed, continue the loop without reactivating the loop every time it hits that spot.
TIA
Posted Fri 14 Jun 24 @ 10:10 pm
remove the autoloop
action poi like this
loop ? : loop 4 & wait 8bt & stem_pad 'acapella' on
Posted Fri 14 Jun 24 @ 10:38 pm
locoDog wrote :
remove the autoloop
Perfect....and made it look so simple...lol
Posted Fri 14 Jun 24 @ 11:32 pm
