I'm on a Macbook Pro and I'm trying to figure out how to zoom in on the waveform in the BPM editor. I've tried all the key combos I can think of (command-click etc.) But nothing's working. I've also done a search to no avail. Is this possible? I know it's supposed to be the mouse-wheel, but the Macbook only has a trackpad.
Posted Tue 11 Jun 24 @ 6:24 pm
track pads usually have a scroll gesture either right side of the pad or two fingers swipe.
Posted Tue 11 Jun 24 @ 6:29 pm
Wow, thank you! I thought I had tried everything, but that worked perfectly.
Posted Wed 12 Jun 24 @ 1:00 am
you should look into track pad gestures, there might be a thing or two that will apply to all machine use outside of vdj.
Posted Wed 12 Jun 24 @ 1:19 am
