Hello,
I've noticed audio dropouts and glitchy distortion if padfx echo out on stems is left enabled for awhile (usually 1-2 minutes). The dropouts start small and occasional but get more consistent. In this video I have the left deck playing and the right deck fader down with echo out for vocals and drums on, with peak audio processing exceeding 100%. The distortion is showing up on the left deck without any effects. When I disable the vocal echo out on the right deck, the distortion on the left deck goes away and audio processing drops to an expected amount.
https://www.youtube.com/watch?v=eywwAIfpOEM
The padfx script is: padfx "echo out" 70% 0.5bt 0.65 0.22 smart_pressed "stemfx:Vocal"
This video was taken using v2024 b8184 but I had similar occurrences on 8195.
Thank you!
Thank you!
Posted Tue 11 Jun 24 @ 3:34 pm
This appears to be fixed as of early access build 8217 (2024-06-18) "Fix Echo Out performance issue when active for a long time". I am no longer able to reproduce the issue.
Thank you!
Thank you!
Posted 6 days ago @ 2:51 pm
