Well, i have a concurrent problem that beyond 4 hours and some minutes, vdj stop recording audio and i need to manually stop and start the recording.
This take me to losing a lot of complete sessions because i forgot to re-record every 4 hours... there is a solution on this ?
Posted Thu 06 Jun 24 @ 5:41 am
.Wav has a hard limit @4 GB that can't be avoided, why are you recording in wav? Why not .flac
Posted Thu 06 Jun 24 @ 5:58 am
nice info right there, switching to flac, without doubt.
i'm using wav because the no-compression and using on video editing, but... needs must.
many thanks !!
many thanks !!
Posted Thu 06 Jun 24 @ 3:35 pm
Note that even with wav the recording is not supposed to stop, but should have continued automatically with a second file.
Posted Thu 06 Jun 24 @ 3:59 pm
Nope, that's not happening, only cuts there around 4 gb and the rest is lost.
Posted Thu 06 Jun 24 @ 4:19 pm
Are you recording at 24 bit? I ask as you should get more than 4 hours at CD quality.
Posted Thu 06 Jun 24 @ 4:32 pm
Yes, sometimes goes up to 4:30 hs but sometimes cut earlier.
The point is that the record stops abruptly without noticing, no problem in using FLAC anyway.
Suggesting at least give a warning info or some message, or check it out the second file recording which is not working ( not at least to me )
Posted Thu 06 Jun 24 @ 4:38 pm
