Hi!
I have the following command on a button:
deck left eq_mid -0.05 & deck right eq_mid +0.05
Now I would like to make the change (here by 0.05) dependent on which other button is pressed. To do this, I have assigned 3 buttons with:
set '$eqdelta' 0.05
set '$eqdelta' 0.10
set '$eqdelta' 0.20
and the following command on another button:
deck left eq_mid "get_var '$eqdelta'" &
deck right eq_mid "get_var '$eqdelta'"
Unfortunately this does not work! How can I implement the negative values?
And then a knob should not be able to be turned further than the center (=0.5).
param_greater "deck right eq_mid" ? deck right eq_mid 0.5 : nothing
unfortunately does not work either
Does anyone have an idea?
set '$eqdelta' 0.05
set '$eqdelta' 0.10
set '$eqdelta' 0.20
Posted Sat 25 May 24 @ 11:05 pm
The only param type eq_* accepts is a value [either absolute or relative, a number or a ± number] and that can be expressed as a float 0.0-1.0 or as a percent 0-100%
It does not accept an action as param.
To pass a variable you do this
to pass the value as absolute
to pass as positive relative
to pass as negative relative
Your query is incomplete, you have no value to compare against.
param_bigger 0.5 `eq_mid` ?
[is mid higher than 0.5]
get_var $eqDelta & param_cast & eq_mid
get_var $eqDelta & param_cast relative & eq_mid
get_var $eqDelta & param_multiply -1 & param_cast relative & eq_mid
Posted Sat 25 May 24 @ 11:47 pm
Hi!
Great! That works! I've been looking for it for hours! Thank you so much!
Posted Sun 26 May 24 @ 3:25 pm
