Topic: Idea: AI Trained on VDJ Forums and VDJ Script
If I can be honest, I find the using the search on this site for info in the forums to usually be fairly useless and having to Google search "[thing that I want] virtualdj" gets annoying quite quickly. What if there was an AI that was trained on the forums here? I'm thinking kind of like Bing/Copilot for citing sources, but specifically for Virtual DJ's site and forums where there is a ton of information about using VritualDJ. Oh, and maybe one that understands the scripting in super deep detail -- that way locodog isn't the only line of communication with the depth of knowledge to own all of the super crazy scripting support requests ;-)
Posted Thu 02 May 24 @ 3:49 am
The forum search is grim. Seriously needs some TLC. Better to use Google specifying the site as its far more accurate
For searching it would be fairly easy to setup with copilot, although search optimization engines may be better than an "AI" based one (AI based is almost never the best solution for specific problems)
For learning a scripting language, I don't think nearly enough VDJ script exists in the world to be able to create a copilot like experience. It will need millions of examples to train on, with meta data on what they do
Agreed. Glad it's not just me that finds the forum antiquated.
I suggest we ask Locodog is he would mind being fed to the AI machine just like in a Superman 3? For the greater good and all that. :D
...6502 architecture and an ethanol based power supply...
Yeah forum search is kind of bad, it doesn't help that a lot of searches would be 3 char abbreviations, Field types author, date range, "exact quote", would be useful, honestly google is getting kind of bad at search results these days too.
I keep browser bookmarks of everything I find interesting and I try rework interesting script concepts into the script school thread, I know I prattle on but if you pick up some language fluency from that thread you become easy to answer.
One day it'll [a.i.] get there [probably by derping around with 'network control' plugin], until then, I run on beer & I won't trade your browsing data to advertisers.
Apologize in advance, if hijacking the thread..
Thinking of what one would wish AI to do..
Would love for an AI assistant to set cues and loops, after it has trained on the style/method, from the currently 5000+ prepared tracks.
(would be unique to each DJ)
And one could just review the AI set cues, .... with any corrections leading to additional learning/accuracy.
I did just want to mention that I've been messing about with Code Copilot within ChatGPT and have found it to be moderately competent at scripting for VirtualDJ. For example, I asked it:
I am using VirtualDJ with a Pioneer DJ DDJ-FLX10. I want to have the dualdeckmode of the Pioneer DJ controller work in parallel with stems_split_unlink such that if dualdeckmode is on then stems_split_unlink will be off and if dualdeckmode is off then stems_split_unlink will be on. This script will be assigned to the shift_deck_13 and shift_deck_24 keys. What is the correct way to script this?
And I got
Here's the script for shift_deck_13 and shift_deck_24 keys:
dualdeckmode ? dualdeckmode off & stems_split_unlink on : dualdeckmode on & stems_split_unlink off
At least it so far seems has been useful a few times when I was stuck on finding the correct logic or needed a starting point for an idea.
