Hi,
there is the smart_fader feature that can synchronize the bpm of 2 tracks step by step automatically during crossfade. But it also swaps the bass during this transition automatically. Which is fine in most situations, but sometimes I want to keep the basses untouched.
Question: how can I use the smart_fader feature, but disable bass-swap during the transition (so bass is untouched)?
Thanks
Thanks
Posted Sun 24 Mar 24 @ 10:33 am
The script is as you see it,
I worked out the maths required for the pitch change [it can be done with current script] and made a virtualfx that monitors the xf position out of it.
Posted Sun 24 Mar 24 @ 3:08 pm
So it's not possible to say "don't touch the bass during the transition"?
Posted Sun 24 Mar 24 @ 5:17 pm
not with smart_fader, as you see it, is how it works
this is the thing I made that doesn't effect the bass
Posted Sun 24 Mar 24 @ 5:22 pm
