Topic: Vst plugins - Page: 2
That video is outdated. VSTs are not DLL files any more, and it's also not necessary to copy files to the VDJ folder.
The VST installer will put the file in the required directory. The procedure for adding the directory to VDJ is in the VDJ manual.
VST 2 Still works and they do still exist :-)
I'm aware of that, but the particular VST this user downloaded has a VST3 included, so.......there's no need for a DLL and no need to copy files anywhere.
Thanks as long as I can get a Vst to work is all that matters. I haven't used any since I downloaded this software. What's up with the Reverb in Virtual DJ? Maybe Im doing something wrong but I don't like the sound of it. I tried adjusting it but I can't get a sound I like. Idk
I don't understand Vst or Vs3. I'm thinking the 3 means newer. Whenever I downloaded that file and installed it. I went back and looked in Virtual dj effects and it wasn't there. I saw all the others though. Brake, Backspin ........ But not that one. So it doesn't automatically put it in there. I don't know if I have to turn on or off some settings. I'm familiar with this stuff also. We had Atomix a long time ago and we just dragged the file in the effects folder and it would appear. This version isn't as easy like it use to be
setting vstFxFolder
locoDog wrote :
setting vstFxFolder
Thanks
