Hi everyone.
I'm very new to VDJ, so it's quite possible that I'm doing something wrong here.
I'm using the latest version (as of writing this) v2023-m b7921 on a M1 Macbook Air.
What I'm basically after is to have the parts of the stems that are turned off, greyed out on screen or even better - completely removed (if thats possible). When I read the cursor info pop-up , it looks like WaveGreyOnKill option would do what I'm looking for, but it seems to have no effect whether it's on or off. I still have the complete waveforms scrolling on the screen. No matter what I've tried, the WaveGreyOnKill option doesn't seem to be working for me. Is this a bug, am I doing something wrong or does it simply not work with stems? Thanks in advance.
Posted Tue 12 Mar 24 @ 11:08 pm
Are you using shapes wave type?
Posted Tue 12 Mar 24 @ 11:09 pm
HI & thanks so much for responding.
No, I was using colours. I changed it to shapes & now it's working exactly how I want it to.
Geez, I have a lot to learn still.
Problem solved.
Thanks again for your help.
Problem solved.
Posted Wed 13 Mar 24 @ 2:49 pm
