Topic: virtual dj entry point not found
I have a laptop x64 running on Windows 10 Home edition. Have installed the latest version of Virtual DJ. When I open the software I get a virtualdj.exe entry point not found Error.
Have tried installing Direct X and also Visual studio C++ redistributable for 2013 and run SFC /scannow
Still hasn't fixed the issue. Kindly assist
Posted Wed 14 Feb 24 @ 9:37 am
AdionPRO InfinityCTOMember since 2006
Make sure to update your Windows 10 as well
Posted Wed 14 Feb 24 @ 9:42 am
I have the same error as you:
virtualdj.exe - Entry point not found.
Unable to find the entry point for the GetUserDefaultGeoName procedure in the dynamic link library C:\Program Files\VirtualDJ\virtualdj.exe.
My PC is Windows 10 Pro 1607 64 bits. DirectX OK; Microsoft C++ 2015 2022 OK; Drivers OK.
I've already done: sfc /scannow; MSCONFIG; CHKDSK; DISM /Online /Cleanup-Image /ScanHealth and DISM /Online /Cleanup-Image /RestoreHealth. Nothing worked. The error continues. I need help.
virtualdj_2024_b8184_pc
Posted Fri 14 Jun 24 @ 12:48 pm
Windows 10 1607 is 8 years old now, and no longer supported by microsoft
Posted Fri 14 Jun 24 @ 1:42 pm
Hi Guy, thanks for the tip. I'll try to do that. :)
Posted Fri 14 Jun 24 @ 4:15 pm
Tengo una hp probook Windows 10 64bits. Acabo de actualizar virtual dj y me tira un error. "NO se encuentra el punto de entrada del procedimiento GetUserDefaultGeoName en la biblioteca de vínculos dinámicos C: program Flies/virtualDj/virtualdj.exe. Por favor que puedo hacer, es la primera vez que después de actualizar me arroja este error.
Posted Fri 14 Jun 24 @ 8:32 pm
Posted Sat 15 Jun 24 @ 5:19 am
Me to facing the same problem entry error
Posted Sat 22 Jun 24 @ 12:04 pm
Same solution, update your windows
Posted Sat 22 Jun 24 @ 12:11 pm
and what if it doesn't work ?
because I'm updating my windows, I'm even scared of updating my windows 10 because it crashes my pc almost all the time that I have to flash it.
Posted 3 days ago @ 5:37 am
yep
I KNEW IT AFTER 12 HOURS OF UPDATING THE WINDOWS I KNEW IT WASN'T GOING TO WORK AT ALL
TO BE HONEST I PREFER THE OLD 2021 VERSION THAN THIS SHIT TODAY
Posted 3 days ago @ 3:09 pm
You need to go back to basics dude.
Posted 3 days ago @ 3:50 pm
how please ?
Posted yesterday @ 10:48 pm
