Topic: How to add comments to VDJ scripts?
Hi,
I have written some rather complex script buttons with multiple conditions.
Do better remember what the intention was, I would like to add comments to the script. Is that possible? Something like the following pseudocode:
cue_name 1 'Intro' & #"this is just a describing comment"
Posted Thu 08 Feb 24 @ 3:27 pm
As long as it isn't in the position of a possible parameter you can add comments in " " anywhere so long as it has & either side, it will ignore what isn't script and just carry on reading
set someVar 1 & "this var is for something" & effect_active echo on & "i turned the echo on"
or you could just comment on the end
set someVar 1 & effect_active echo on & "this var is for something + i turned the echo on"
